Cooling system vent plug
- Thread starter DavidL
To bleed the coolant warm the engine with the heater set to fullly hot (so the whole coolant system is in circulation) until the rad fan comes on (so you know it's hot enough for the thermostat to be open), switch off the engine & carefully crack open the bleed screw. Let any excess air out, tighten the screw back once the coolant start to escape (ie all the air is out).
The car should be level or pointing up a gentle slope (so the bleed screw is the highest point). You may need to repeat the cycle a few times if there are several air pockets in the system.
