DavidL
Can someone confirm to me:
Both fans run at both speeds. Mine is a 90G turbo and I have a suspicion that the fans are not running at the slow speed.
But I'm a little confused as to whether there is one slow and one fast fan or whether both run at both speeds?
I need to do a few tests and see what happens if I switch off when the fans are running. If the slow resistor is at fault then both will go off ( I think earlier cars only ran one fan with ignition off).
Anyone confirm or correct my thinking?
