924nutter
Hi guys I'm sure there's been a thread about this before but I can't find it. My 1992 944 Turbo cab has just developed a problem with the cooling fans. When the engine is stone cold they are inoperative, but once the engine is up to just its normal operating temperature they come on at full power. Upon turning the ignition off they do not reduce to the slower speed as they used to, and I am sure they would contine to run until the battery was flat. The relay clicks and chatters when the ignition is switched on from cold. Last night I disconnected the battery and took out the relay then reconnected and the fans stayed off ( no surprise there) but when I replaced the relay the fans did not start straight away but did start again on full power after about a minute. I am suspecting the fan control sender in the radiator. Anyone had a similar symptom who knows what the fault is? The car has done 44,000 miles.
