I heard a slight gurgling liquid sound the other day, from behind the dash. I suspect I have a bit of air in my coolant, and I know that my coolant low and due a top-up anyway. So, my questions:-
Would you just top up the coolant, or would you completely drain the system and fill it up from scratch? If you think I should renew it, then I'll have a load more questions. If it's just a nice-to-do job, then I might top up for now and renew the coolant in the spring.
I understand that phosphate free coolant is required, is Prestone the right stuff to get?
I also understand that tap water is not ideal to use due to its content of minerals. I have a dehumidifier running most of the time at home which produces a few litres of water a day, could this be used as 'distilled water'?
