Sandspider
Hi all
Noticed a bit of drop off in coolant levels recently, and think I found the culprit today. Took her for a drive in the cold, and heard a bit of a hiss when I got back. Opened the bonnet, and there's steam coming from the radiator. It's so cold and wet I can't quite tell where it's coming from, but it seems to be from the top left of the radiator (as you look backwards down the car). That said, it also seems to be leaking out from under the badge panel / behind the metalwork of the bumper, so could be spreading and escaping from several areas.
Are there any common (and hopefully easy to get to!) problems around the top left of the radiator that can leak steam? Don't really want to have to get under it in this weather! [&:] The hose & clips at the top left of the radiator seem to be OK, though I can't really see all of it. Will look again if the rain / sleet / snow stops
Cheers for any suggestions...
