cone air filters.
- Thread starter ocallen
Copperman05
Edd
sawood12
JamesO
Also I'm getting manifold pressure spikes since the filter went on so Scott is probably correct. It does sound good though and pick up over 4k is better.
The intake temperature does drop to ambient at speed but I don't trust the filtering properties of a cone filter so it won't be on my car for long.
Long story short - the results are the best when you have an air box with a *new* high flow rate panel filter in. Cone filters are great when the engine bay temp is low - but in traffic or in a heavy run they actually can have a negative effect.
Also, the fact that you dont replace them - no matter how much you clean them, you will never get the flow rate from a used cone filter than you do when you first put it on, that is actually also the case with the re-usable panel filters...
To that effect - I ran a standard (saab at the time) panel filter and just threw it away every 6k... easy...
A
