ORIGINAL: 944Turbo
Other coolant leaks can be hard to spot, do you have the hard pipe that runs above the exhaust manifold this sometimes goes to pinholes which spray onto the manifold and the coolant evaporates almost immediately.
Tony
Sorry to tag on [8|]
I've had a small coolant leak that appears to be coming from where the hard pipe joins the small rubber hose that joins the water pump, the small rubber hose has been replaced twice and I had recently tightened the jubilee clip with a spanner. This seemed to solve it for a week but then it started again, can clearly see the spray residue around the hard pipe area. I use my car as a daily driver and the leak isn't that bad (about a litre a month).
Has anyone else had a problem with coolant leakage from the hard pipe above the manifold? Is it worth replacing it?
Dave K.
