COLD START PROBLEM
- Thread starter rogero
alwigley
peanut
Cold start fuel injector not working Engine temperature sensor faulty ! Sticky injectors Faulty FPR (low Fuel pressure) Faulty Auxillary air valve Low fuel level in tank (fuel pump not fully pressurizing system) When it runs from cold does it blow blue smoke ? or sound lumpy and rough until it warms up?ORIGINAL: rogero 944S2, wont start from cold but has 100% spark, fuel supply and compression. However if I inject a squirt of fuel into plug holes or through the air box it starts immediatly. once warm it's all ok. Any ideas please, it strikes me its a sensor or valve not working
robwright
The Idle Control Valve ICV is exactly that. It operates under the control of the ECU (DME) when the engine is idling. It serves to keep engine revs constant under varying loads i.e. PAS, aircion, heter blower or demister. It does this by opening and closing to meter varying amounts of air into the intake manifold to schieve the set RPM point. It is a closed loop system. Cold start mixture is controlled directly by the DME at the injectors.ORIGINAL: alwigley 1. Hidden under the intake manifold is a cold start valve known as the idle air control valve (or similar) which I believe only operates on cold starts - this sould be giving issues and failing open, resulting in a weak mixture.
peanut
bertelli_1
robwright
I have to agree with you bertelli. Where is this mythical cold stat injector fitted? It is not fitted to my injector rail. I have had it to bits along with the manifold and it does not exist. The DME only has one temp input, a signal and return from it's temp sensor. Check the diagrams.ORIGINAL: bertelli_1 The S2 - or any other 944 for that matter - has NOT got a cold start injector. On that basis we can discount it as being the problem! eta: are all the vacuum lines intact, particularly the ones connected to the fuel rail?
peanut
what would you say this is ? The thing with an electrical supply from the injector harness ? I've always assumed it was the cold start injector. The Bosch manual states that the Motronic 2.1 system has one ? Early 944's I know have a cold start mechanism which the ECU controls and gives a temporary boost to the fuel injectors when cold. If the S2 has the same system I stand corrected and will amend my previous post but the cold start system is still a likely culpret for a lack of fuel when starting cold. One thing we can probably rule out is the vacuum lines I should have thought. [ORIGINAL: bertelli_1 The S2 - or any other 944 for that matter - has NOT got a cold start injector. On that basis we can discount it as being the problem! eta: are all the vacuum lines intact, particularly the ones connected to the fuel rail?
robwright
