bmnelsc
Hi all - I have a '91 S2 (LHD but imported to Canada from Japan) with low miles indicated (48K when I got it and 4 years later 55K now). It is parked over the winter months here so runs from May 1 to November 1. The release bearing was noted as noisy during the PPI when I bought the car and clutch engagement was pretty high on the pedal. No way of knowing if this is the original rubber clutch or a replacement with a spring center. The clutch disc "appears" near new with a 20mm measurement taken at the inspection port.
Sometime during my first year, the clutch started engaging about mid travel and seemed to run from none to fully engaged almost like an on/off switch. It was pretty stiff at that point - pedal pushed back hard from the floor to about mid travel. Was like this until a short while ago when it started making a lot more noise during a highway run of about 225 miles. After a weeks rest and a couple of shorter trips, it has quieted down and clutch pickup has moved back up to high on the pedal and effort is much lighter than before.
Does all this sound like release bearing trouble or something else like guide tube binding or what? I'm tempted to pull it apart and have a look although it won't be an easy job for me (old, weak and have to use jack stands) so I have a few questions before I determine if I can tackle this myself.
1. The Haynes 924 manual talks about using a shaped wooden block under the torque tube at the front cross support so it won't fall and potentially be damaged. Is this valid with the later 944s? The Porsche manual makes no mention of the wooden block or other supports on the torque tube.
2. The Haynes manual says to use VW-1022 or an engine hoist to take the weight off the engine mounts (but doesn't say anything about detaching the mounts). The Porsche manual talks about removing the nuts from the engine mounts and pushing the engine to the right before removing the lower bell housing bolts. It also says you only need to support the engine with VW-1022 if you can't easily pull the torque tube back from the engine (excessive rear inclination - check engine suspension). What are they really saying? You need to undo the motor mounts, suspend the engine and shift it to the right? If so - why - is clearance needed to remove the release lever shaft or ???
3. The Haynes manual does not require the torque tube be detached at the transmission end for clutch service but the Porsche manual describes detaching the torque tube, moving the selector rod guide tube out of the transmission and a bunch of other steps. I'm confused????
I'd really appreciate some advice from those who have traveled this path [
