Clutch Problem?
- Thread starter Guest
I tend to get rolling in first gear, minimising clutch slip, get fully engaged and then go for it.
Clutches ssem to be a weak(ish) point on the 911 series, I guess this is better than the weak point being somewhere else in the transmission. [
difficult to spin wheels on dry surface,, mine has 285 rears,, so alot of rubber to spin,, but on wet , slippy roads,, will spin much more easy..
just had clutch replaced... and behaves the same,, but they replaced some bushes on the yoke mechanism which makes clutch pedal,, very light,, so better in traffic..
bill f**!!!!!
so treat it gently,, or dig deep into the pockets
1997 c2s
regards
scott
DESMO16
My 993RS is running an uprated "Clubsport" Clutch with single mass flywheel.
In the dry you would have to really dial in a lot of revs and drop the clutch to provoke it to spin the rears in a straight line.(something I dont wish to do that often).So normally it is usually the clutch that lets go first!!!!!!!!
All the 911s that i have owed in the past have all been similar, regardless of model and as pointed out in a previous post , it is better for the clutch to slip, than expensive damage to your transmission!
John
Anyone got a fix on what it should cost to have a replacement clutch fitted?
Is there anything else that should be done at the same time (e.g. bushes on the yoke mechanism)?
Cheers and best wishes for 2005.
peterarcher
Cheers Peter [
