FistsOfHam
Whilst I'm overhauling the clutch hydraulics on my 944 I figured I may as well replace the seals in the master cylinder. The inside of the piston housing is fine without any pitting or scoring so just a new set of seals and a lick of paint on the outside will sort it out.
Problem I'm having is where can you get the seals from? OPC say that they don't supply just the seals but can do me a new MC at somewhere hovering around £90 which after just buying a new slave I'd rather do without. I have already dismantled the part once and the seals had a layer of crud on them which was easily removed using a fingernail but they are dented in the middle which is less than ideal.
If the seals aren't available separately then I'll just replace the dust cover for now which is torn and replace the whole part at a later time.
