Cheap piwis/durametric
- Thread starter jetbox
If you are serious about diagnostics, and think your next car may also be a Porsche, I would recommend biting the bullet and purchasing the genuine article.
thirteeneast
I have used my cable with 5 in the past but its iffy.
go to www.uobd2.com , type in piwis on search box ,click on lead info , software is in related down load files (download piwis cable zip)
also i have bought a lead from another site , i found this info when looking into lead suppliers
hope this helps
thirteeneast
But it say's that version 5.
Which does work but I think v3 is a lot more stable for a snide.
ORIGINAL: Diesel130
Is the specification of the data for the porsche-specific diagnostics openly available? If so, how hard can it be to write an application to read/write the necessary information?
If not, then how do Durametric do it, by trial and error?
In the early versions of the Durametric software just so. All you got was the OBD error code plus a German version of what the code related to via a lookup table.
Over the years this has been improved, English code lookups have appeared though some German ones still appear once in a while.
They have also added better help files and the ability to reset and code some of the more common control units.
Diesel130
I would have thought that Porsche keep that information confidential to themselves, but if so, how do Durametric make a device that can read and write Porsche specific codes?
ORIGINAL: thirteeneast
Anyone point or PM me to a corner of the WWW that might be hosting version 3 as Durametric no longer have it on there site just 5 & 6?.
If you have not found a copy yet PM me your email address and I will send you a zip file with version 3.
Mine works ok with both 3 & 5.
chriscoates81
chriscoates81
Personally, I would go genuine, especially if my next car was likely to be a Porsche. Yes, it is expensive, but if you are serious about DIY then a decent diagnostic tool is essential. The complication of the electronics on P-cars is only going one way.
thirteeneast
RANGE 1, 7200-7500
RANGE 2, 7500-7700
RANGE 3, 7700-7900
RANGE 4, 7900-8400
RANGE 5, 8400-9500
RANGE 6, 9500 and over
I wouldn't worry, it was such a long time ago that if it had done any damage it would have manifested itself by now.
If you look at the version history on www.durametric.com you will see the improvements and bug fixes since then, but at £33 it is a whole lot better than nothing.
Now wasn't there someone here looking for the V3 software? (Post #6) . Edit: Too slow!
