central locking
- Thread starter Alpine
I have already attached it back together with a retrimed door card after the temp fix.
It will be much appreciated for the part num if its not much trouble. The temp fix seems to work atm so its not that urgent really.
Interesting after fixing the split one the other door lock now feels more troublesome. Maybe I should replace the two altogether.
ashley
ORIGINAL: homesea
. It unlocks but will not lock with the key. It used to have resistance when you turn the key then it would spring the key back to the horizontal position but now nothing. Thanks.
Having just gone through this whole saga with my drivers side lock I may be able to help,
On mine having removed the door handle, (but not before snapping the rod connecting to the handle trigger,[
After soaking the barrel with WD40 this freed them up and with the key retracted they popped out with the aid of a tiny spring, one for each lever. These levers locate into a groove in the barrel housing. Re assmembly is the reverse and can be a bit fiddly getting the key and lock mechanism centered on a toothed cog which locates into the central locking solenoid switch. With everything reassembled the resistance on the key returned.
Sorry I haven't got photos, it was one of those jobs I started thinking it would be a 5 minute fix and ended up being a couple of hours, though doing it again would be much easier knowing how it all works.
Wigeon Incognito
My S2 certainly did before I changed it to remote.
pauljmcnulty
