OK... I have a 91ish (I think - what is "H" reg?) S2...
The central locking hasn't worked since Ive had the car. There is no fuse in "Fuse 8" slot, and if I put one in, it blows. Clark's garage reckons Fuse 8 is for the central locking, but the Porsche Diagram appears to say fuse 12 - both diagrams suggest the other is unused.
Anyway... my best guess is that one of the wires going from the body to the door has chaffed... I have looked at the passenger door so far, as I also have a problem with the lock button (namely it can be lifted out, but it would appear this is just because the button is broken).
My problem now is that there isn't a connector for the door harness where I expected to find it (just in front of the door, behind the footwell side panel).
Anyone know which fuse it is likely to be (I'm guessing a shorting fuse and non-working CL kind of go together!), and where the door loom connectors are located?
TIA,
Tref.
TIA,
Tref.
