Cayman Sports Exhaust - valve failure
- Thread starter Motorhead
AndrewCS
Not totally unexpected given the history with these items and covered under the extended warranty
Also highlighted was that all the exhaust fixings were corroded, although not noted back in October during the six year service. Given that half of the fixings come under the warranted muffler replacement I was offered to change the offside fixings for ~ £300 (including PCGB discount). I declined the offer given that this side`s muffler valve is also likely to fail - seize soon !
The valves are located below the actuator (6) bracket
I understood that silencers (mufflers is American [
Are you saying that one silencer is being replaced under the extended warranty?
Two years and two months later a valve failed. The actuating arms sheared through corrosion. Yep you guessed it ..... sorry sir its out of warranty !!
I purchased a valve form the OPC and fitted it myself. Pretty straight forward job really as none of the clamps or bolts were corroded.
Good luck.
It does seem a common failure point, on most Porsche models.
https://www.caymanoc.com/forums/topic/2122-pse-issues-9872s/
Its primarily (my) 987 focussed, but has a a bit about the 981 in it also.
in short, it seems OPC part catalogues don’t include the pneumatic valve actuators as separately available components for Caymans (thus telling you you need to spend £000s), when actually the equivalent 997 / 991 valve actuators are the same part no. as those fitted on the cayman, and are available to buy separately for ~£100.
go figure
not only is there a Porsche tax, but it would seem there’s also a further Cayman tax…
AndrewCS
The picture in post 1 is from a 2013 - 2016 Cayman 981 Model C14 PET catalogue, the vacuum [
The 987 (2009 - 2012) Model 987209 PET catalogue shows the valves & actuators but does not itemise them hence no part number
The 2016 981 GT4 Model PET catalogue shows the actuators 991 111 381 02 / 991 111 385 01 but not the valves
Without warranty I would be leaving it in it`s `failed open` state and disconnecting / plugging the vacuum line from the other side, to ensure that it also remained open
unless one desperately no longer wanted the option of ‘quiet mode’ from the PSE system theres little reason to not change a failed actuator if you’re comfortable using a small spanner, a pair of snips / junior hacksaw (to remove the hose cleat) and some crimps (to fit a new cleat). for those less inclined to wield tools on their Porkers (and out of warranty) an Indy should be more than capable of this task - it’s literally 3 nuts.
one can certainly save thousands by avoiding replacing an entire silencer / muffler for the want of a ~£100 valve actuator is my principal point.
Paul Dodds
I've had 4 exhaust replacements in 5 years. The valves keep seizing. Anyone ever had a suggestion for a permanent solution from Porsche? Costing me £1,000 a time or an extended warranty to cover this cost... for a part that continuously fails and is clearly not fit for purpose. Dealer can do nothing, Porsche GB won't address. Anyone had any positive experience?
Having said all that, the valves on my 981 have seized up, but the arms are still OK. So 10 minutes with a pair of mole grips, some penetrating fluid and then copperslip has got them back to a functioning state.
Paul Dodds
Last failure (of many), waited months for replacement exhaust system (always told actuators cannot be serviced/fixed). Once I started trying to contact Porsche Germany did a set miraculously appear. At this point, Porsche GB’s position was (you know… we’re just the importer…). This was beyond pathetic for me.
While fixed under warranty, the only reason I paid for a warranty was to take care of this problem that I knew would come again. This is a twisted position to be in with a brand like this.
So, it’s over for me. Good luck people.
