Cayman 718 rear lights - condensation
Yep, I had a front indicator lens replaced late last year as it filled up pretty badly with water droplets. Misting is perfectly normal but this was clearly worse. My claim was initially rejected earlier in the year, so you may have to wait until it gets worse before it's accepted?
Was it done under the extended Porsche warranty or the normal 3 year one?
Nice one Dan, much appreciated, they say it is not L4. I am off to Spain in 10 days for a road trip so I will see how it goes then and chase up on my return.
Thanks, that was my thought as well. But it is like the proverbial "Pulling Hen's Teeth" to get a claim accepted, there is a technical bulletin (Ti9415) which covers this problem that was first issued in 2016, apparently they have 4 stages of condensation/water in light units and only stage 4 qualifies for replacement. I have sent another picture over this morning and I am currently waiting for an answer on if it is claimable.
I had one of the front marker lights replaced under warranty as that had large water droplets in it so I can't understand why this claim is any different. I have never had any warranty claim issues on a host of other vehicles in the past but this is leaving a bad taste.
I had condensation in front and rear lights of my cayman. Dealer said it is condensation and the lights are vented and it clears after about an hour, so not able to claim on extended warrant they have said
A mist of condensation is totally normal front, rear and side. Both my Caymans had/have it regularly and it's not an issue.
Water droplets, pools, puddles etc like in the above pics are not normal though! :)
I disagree. Never had any issues with my previous Cayman which I owned for 4 years from new, and my current car which I've had for 6 years from new has just had the single issue on the nearside front indicator. Both cars live(d) outside in all weathers and the units have held up well so I don't think there's a major issue with them.
YMMV of course.
Update:
The only offer I ended up with via the dealer was a goodwill gesture of £550 towards a new light unit, leaving me to folk out £400 on a car that is not yet 12 months old so I have taken out the N/S/R light unit to try and get it 100% dry inside before refitting it and see if that makes any difference.
I have attached a load of pictures which I hope will prove useful to other folk who want to see the light unit from all angles, I believe the blue cap labeled "denko nitto" (circled in green) is the venting system, the other "vents" do not have a cap and end in blind holes, I would like to remove the blue cap but with a little tug/twist the thing does not move and I do not want to mark/break it for obvious reasons.
There is an odd left handed screw (circled in blue) which looks like a cable entry point but it is not that, anyone any ideas on its function?
The wiring harness looks to be poorly fitted as well (circled in red) with a clip not fitted correctly and one of the cables rubbing on the sharp edge, I will sort both of those issues out.
20260731_154054.jpg20260731_154058.jpg20260731_154103.jpg20260731_154113.jpg20260731_154135.jpg20260731_154233.jpg20260731_154242.jpg20260731_154409.jpg20260731_155412.jpg20260731_155422.jpg
I suppose you could try contacting Valeo UK customer services on 01527 838 300 or vsa.uk-customercare.mailbox@valeo.com for advice.
Jeff
Nothing to loose by trying that Jeff, thanks for the suggestion, BTW my local dealer told me Hella made the rear lamp units, I would imagine that Porsche would have two supply chains "just in case". The wiring loom was made in the Ukraine and I was surprised it was fitted in such a fashion with a cable rubbing that way and a clip in the wrong place that is of no use.
Here is a quote from the reply that Valeo technical send me today, they are referring to the "blue cap":
  • "This is a breathing vent designed to let air flow while blocking water and dust. If it is blocked, torn, or unseated, moisture will trap inside.
  • Light misting that clears quickly is normal, but heavy, persistent moisture indicates a venting or sealing issue."
If it was a 987 series car it may have had a different light setup. I think the misting could be a 981/718 thing.
I've not owned a 987 so I'm unable to comment on those cars.
Touch wood I’ve not had this issue on my 987.2 with PDLS Dave, but the car’s garaged which may have some bearing on the matter.🤔
Valeo tech’s response to A-S’s message suggests that the breathing vent may not be doing its job if moisture presence is persistent, but getting a dealer/Porsche UK to return the units to Valeo for inspection is highly unlikely.
Jeff
It may be worth sending your service advisor a copy of the email that Valeo have sent you. This may back up a warranty claim.
Dan
Dan
I considered doing that but as Porsche have already given a goodwill gesture the dealer have washed their hands of it now, I will have a chat with Porsche CS and give them Valeo's opinion.
As the other side works correctly and the N/S does not you would think that is enough to demonstrate a fault.
Never had a problem with lights misting when I had my 987 Cayman (2007 model) and it lived outside
