Cayenne Towing
boothy
Hi all,
Has anybody any experience of using the Cayenne as a tow vehicle?
I am likely to need one soon and as there is now a cheap(er) model now available it becomes a possibility.
Any experiences, good or bad, gratefully received along with any other useful option suggestions if used for towing - air suspension?
Melv,
Thanks for the sole reply.
Can't be many 'towers' on here !
When was the article? As a newbie I only have the last 3 issues of PP.
I'll have a look, but basically he was mighty impressed towing his race car and various others. It replaced a Range Rover. And he can still outdrag most things from the lights, WITH a loaded trailer...
Be very afraid..... [:D]
Mel
Someone ?
Pleeease !
Surely more than one uses a KN for other than shopping and quick trips to the garden centre![:D]
Just go ahead and tow -it won't be a problem!!
NB, if you haven't towed b4, there is a lot of advice on the 'net, + courses avlble.
ORIGINAL: boothy
Ask Club for a back number.
Mel
should be ideal - the recomendation is that the weight of the vehicle being towed is less than 85% of the weight of the towing vehicle, this leaves a huge range of options out there for you therefore. The Toureg has been tested as a tow-car and comes highly rated - the cayenne should therefore be even better. I would suggest the air suspension as it add extra stability. Just stand back and wait for the wails and knashing of teeth when the purists see their first cayenne towing a caravan however!!
