Cayenne eHybrid charging issues
richard.murfitt
After 2 years of ownership I am still having issues with timed overnight charging of my 2024 Cayenne eHybrid.
it regularly doesn’t charge or doesn't charge fully when using the scheduled departure option in the app Regardless of what setting I use.
works fine if ‘direct charging’ is on.
I am using vorsprung chargers I have a 7kw and a 22kw.
I have also used the chargers timing system but the car doesn’t play well with that either.
Anybody out there having similar issues?
Also am I the only person annoyed by the car’s insistence on charging to 25% when you first plug it in when direct charging is off?
any thoughts?
any thoughts?
I too have had issues with charging my hybrid Cayenne. Firstly, make sure you have the VERY latest app updates as they are updated on a regular basis. Force an update if necessary by going to your app store. Secondly, I am with OVO energy and their charge app allows you to modify the smart charge schedule to be nearer the finished charge time shown on the Porsche app so the two are roughly in line. Once again, each iteration of OVO charge app seems to work better than previous so make sure it too is the latest version. I don't play with the car onboard scheduler at all. Hope this helps!
My MY24 Cayenne eHybrid has been fine so far. I don't use the timer in the Porsche app though. I use the Zappi charger / MyEnergi app to manage overnight charging. The Porsche app shows an error when I plug it in but then gets overridden later at night when the Zappi starts the charging cycle. Charges to full in 2-3 hours. Not sure what you mean by 'direct charging being off'?
Have you asked the OPC to check out the onboard s/w? Maybe try charging it at their dealership?
