Indi9xx
Pete is spot on, the full under-tray, including the metal bit is important to get the most out of the ground effect.
Having said that, above 100mph you can often tell if a car is missing the plastic one, feels almost like the nose is pointing skyward and light.
Amazing that such a simple flimsy plastic part can keep the nose down on a 944 turbo, but its more to do with how the air is controlled and turbulence is avoided, than the tray actually forcing air in such a way to pull the nose down.
Recently had some flying lessons at Bournemouth airport, while talking in the club bar it turned out that the guy I was talking to was a previous red arrows pilot, anyway, we were talking about aerodynamics, and he explained that the red arrows have something that looks like a toblarone package stuck to the leading edge of each wing... the reason is because apparently as the plane hits a certain speed before its stall speed, the small device makes the whole plane shake as a warning.
