Cant unlock sunroof
- Thread starter SUSIT
ORIGINAL: craiginuk
Obvious question - Are you on 1st click on ignition?
I am indeed
If this does not happen with the key in the correct position then you may have a fault with the microswitch at the front centre of the sunroof. There is a very lengthy guide and troubleshooter to the sunroof on Clarks Garage:
http://www.clarks-garage.com/shop-manual/body-03.htm
ORIGINAL: Diver944
With the key in the ignition you barely turn it on until it reaches the first position. Press the button to open the sunroof as normal, only now the arms will lower into the roof and you can lift the sunroof out.
Thank you kind sir
