garyalanlane
Went for a drive today and then parked up for a bit of shopping. When I got back in, started her up but couldn't get it in gear. Clutch pedal seemed to be working fine. Switched off and and put her in gear and limped home in first, thankfully only about 1/4 mile. Left her a few minutes turned her over again but still couldn't select a gear. Repeated this procedure a few times then all of a sudden I could select gears again. Took her for a spin and everything seemed fine. This has now happened about three or four times in the last two years although I only go out about once a month or so. I've checked all the places I should for hydraulic fluid leaks and had a garage check it over although they weren't porsche specialists and found no problems. Any ideas as I'm scathing my head. The car is a 1989 Turbo. With thanks Gary
