Can any of you bright twin sparks tell me how to....
- Thread starter Guest
sidned
It is incredibly easy and can be done in the comfort of your living room. At the top of the mirror base where it meets the door there is a rubber grommet. Use a thin screwdriver to remove this and you will see a philips head screw. Turn this anti-clockwise (holding the mirror housing) and the whole mirror unit will come off. One you have done this, there is a plug that can be removed and you should now have separated the unit completely.
In the warmth of your living room or garage, you can remove the mirror glass (you obviously know how to do this) and you should be faced with three philips screws that hold the motors in. Simply unscrew these and the motors should drop out.
The new motors I purchased had a plug that did not fit my particular mirror for some reason, so I just clipped the wires and reconnected them.
As they say, refitting is the reverse of removal.
Let me know how you get on or if I've steered you wrong in any way.
sidned
