cam
- Thread starter Guest
elvis
I've only done it on an S2, but all I needed was a dti and a magnetic stand, about £15 all in from machine mart. Obviously as the head is ally the magnetic bit is no use but there is a convenient thread that can be used to mount the stand, photo should be attached if I've pressed the right buttons.
Tim
elvis
You won't need to lock the cams to time them in or put the belts on. As I said, you can time the cams in with a DTI (in fact that's the way the manual advises, no special tools mentioned) as per the pic.
I've replaced the head on an S2 and set cam timing, belts etc from scratch with no special tools so other than the belt tension tool I'm not sure what else you think you need...
http://www.cannell.co.uk/Manuals.htm has links to the factory manuals which are excellent.
