Burning Oil
I would say, assuming it is oil smoke that it has to be valve stem oil seals or guides. If it was oil smoke on acceleration it is probably rings.
Stem seals will have hardened and be US and the guides could well be shot if there are a few miles on the motor.
Alasdair
Thanks very much chaps for the responses and suggestions.
I'm pretty sure that it is oil smoke (my description of smoke colour above being a bit vague!).The head gasket was replaced shortly before I bought the car and there are no signs of cross contamination in the oil of water.
Here's a photo from the Combe track day (I'm braking for Camp corner so foot off accelerator):
From what you've suggested I think the evidence points towards valve stems / oil seals - I'm going to Castle Combe today to watch the PCGB racing and I'll try to find Kevin of Alex in the paddock.
I'll keep you posted!
Thanks again
Mick
I had a chat with Kevin this afternoon (he was in quite a chirpy mood as Alex had just won class 2 in the first race!)
When I explained the symptoms he thought it was more likely bores / piston rings than top end, although he said either way it was probably not worth taking the engine apart - his advice was to keep using the existing engine until something catastrophic happens, and then swap the whole engine for a second-hand one (which can be picked-up on ebay for around £250) - of course the risk here is that a second-hand engine may have the same problem!
Kevin remembered my car, which was campaigned by Frank Cortes in the PCGB championship for several years in the mid 2000's. Kevin did not think that the engine had been rebuilt since the car was built (or if it had it was not by him), so it's probably had a hard life!
Mick
He has some memory. I have seen pictures of Frank's old car from when he raced it on the wall at EMC. ISTR he has been racing a 964 in CSCC Deutsche Marques which is used to run in our club championship. I am fairly sure he is a customer of NineX so I guess via them or other mutual contacts you may be able to get some more history on the car. Fairly sure Frank told me the engine had been rebuilt on that car.
Neil - thanks, from a quick bit of googling it looks like Frank Cortes is indeed racing in the CSCC Deutsche Marques championship (car no 77 - 964 Carrera 2). I'll ask NineX if they will pass my e-mail address onto him as it would be good to understand a bit more about the car.
By the way, conditions at Combe yesterday were a bit changeable to say the least - qualifying for PCGB was dry (first thing in the morning), race 1 was drizzly, and race 2 was absolutely p***ing down. Sumpter won C1 from Morris in both, and as mentioned above Alex Eacock got C2 in the first race and I think he may also have got the class win in the second race as well. A couple of spinners but luckily no major accidents.
Mick
