Would welcome any feedback on the problem I have with the braking on my 1994 C2 993.
 Had a vibration under braking.  Suggestions were that, possibly, the disks were warped and that most likely the plates in the
 calipers had lifted causing the pads to sit unevenly.
 Had the disks changed and new pads fitted and also the plates sorted, as they were lifting.
 I have a good solid brake pedal and at high speeds good retardation without vibration.  At slower speeds, however, a vibration
 occurs which is very noticeable.  Went back to the guy who did the work to have the run-out checked.  There was a very, very
 slight run-out but not enough, in his opinion, to be the cause.
 I don't believe there is a problem with wheel balance or with the tyres (Pirelli PZero) although age may be a factor but there is no
 vibration evident at other times, only when the brake is applied.  Could get new tyres but that could be an expensive way of
 finding out!
 I'm confident that the work has been carried out correctly.  The 'indie' who did it comes well recommended; he knows his stuff
 and has serviced this car for many years but cannot offer a solution.
 I really do not want to go down the expensive route of changing parts in the hope of finding a cure.
 Any suggestions, please?
