brake upgrade
- Thread starter Guest
frogisland
this link will explain (hopefully) some
http://www.pelicanparts.com/MotorCity/wmv/brakes.htm
i also have a picture at this link of brake pads (albeit Big Red, S4, std 968)
http://img.photobucket.com/albums/v384/frogisland/993TT-030-Stdpads.jpg
...but your original question - it can be difficult to the 'untrained' eye, the S4 is a very similar to the Big Red if painted red (especially the late S4 caliper which does not have the raised lines/porsche script on the side)
JP
After cafefully studying the pictures of the two calipers i can see the ones im getting are longer than the standard 993(s4's) so must be big reds,by the way where is the best place to get some replacement discs?
eastendr
For discs, I use OEM 993TT drilled discs on the front, Zimmerman drilled discs on the rear. Try Eurocarparts.
I'm not over impressed by the current brake setup and may ultimately move up to an AP racing setup with 6 pots and 355mm or 378mm discs.
Apparently it leaves the big red kit standing and reasonably competatively priced
I didn't have much confidence in the 220 callipers (small blacks) and found the 250's (medium blacks) to be much better.
Stainless steel hoses also give a great improvement and remove much of the mushiness of old rubber hoses.
Neil Haughey
Pads with a higher coefficient of friction will result in more stopping power for less effort but these may require warming up on the track to work properly. Biggest problem that ppl experience with the stock brakes is that they overheat very easilly on track days. IMHO fresh fluid and a set of cooling ducts would be the first port of call.ORIGINAL: RUMS944
I was wondering if it's worth just getting groved or drilled discs and better pads and hoses?
On my own car I have x-drilled disks, ducts, uprated pads, SS braided hoses and ATE blue fluid. It still takes one hell of a lot of effort to get the ABS to come on when on the track with warmed up tyres, but on the road it is in general pretty easy.
ISTR the main difference with the setup on the late turbos is much larger pads.
random hero
ORIGINAL: wizard
Make sure you haven't got a bulge in the rubber lines near the assembly. It is possible the rubber has become very weak with age an can reduce the amount of pressure passed to the caliper.
This happened on my car,i tried a new servo/master cylinder/new fliud and new brake lines and it turned out to be a bulging rubber hose on the back axle where you cant see it !!!
ORIGINAL: Neil Haughey
.....ISTR the main difference with the setup on the late turbos is much larger pads.
No the disks are larger diameter and thicker (32mm) and the vanes within the disks are curved so as to suck air through the disk.
The callipers and pistons are larger and the bolt holes are parallel to the disk not perpendicular to the face.
Neil Haughey
Dose the same hose fit the different callipers?
Hi John i would be interested in the 250 callipers and disks you have ( ill email you).
Where and how much can i get the radial mounts from?
Are there any other benifits from fitting the 250 hubs?
And one more, where do you get the cooling ducts from. Are they ones that replace the fog lights in the bumper?
Thanks for the advice so far.
