scam75
Well-known member
Another one for you.
Since I got my car the brakes have always squeaked a bit. I've been trying to get to the bottom of this with no joy. I now have new discs and pads all round. Rear calipers are fairly new and recently Alasdair and I put a fairly new pair of front calipers from a 993 on the front. These have the same size pistons as the stock M030 ones that came off. There is zero plate lift as the backs are quite new and the fronts were stripped down and cleaned before putting on. The calipers are all moving well and not seized at all.
Now i get the same squeaking as ever and on top of that I get a nasty screech when the brakes heat up! Aargh![
The only things not new are the brake shims. I have two different types on the front, neither of which are stuck to the pads and not in great condition either. Each front caliper has one that looks like a bit of card with two solid circles which go in the pistons and one of the sticky type which was recycled from an old pad (not stuck any more, plus one has a circle thing missing!).
The question is, do I, A: Chuck the shims away and go without them. B: Chuck the shims away and replace with a new matching set. Or C: Don't bother the problem isn't the shims!
Answers on a postcard please!
Stuart
