There is no doubt that the greys should wear disks quicker than the other Pagid pads but disks on the 964RS aren't expensive and if you are competing, add very little in % terms to the overall costs. However, after 6000 road miles on them the pad wear is very acceptable and there is no noticable increase in disk wear.
I have always thought that too much is made of how much pads wear disks. There are some which are stupid in this respect but its usually when using the wrong type of pad for an application.
While I take on board the comments about the RS29, they are nowhere near as good as the greys from cold and even when up to temperature, they aren't as good. I don't think the wear rates would be noticably better but I will know more after Oulton Park.
The figure for the DS3000's is about right and as I said in my original thread, I would certainly give them a go if I started sprinting or hill climbing. However, the comment above is the first time I have ever heard them described as having "minimal pad noise". Everybody I know who uses them (not in Porsches) says they are the noisiest pad around and it was the reason I didn't go for them.
I am suprised to here that the 993RS guys have tried everything out there because I have reason to believe that they haven't tried the greys. I might be wrong, but I don't think so.
So the choice seems to be
RS15 greys - work well and tested on the standard 964RS set up but might be harsh on the disks/wear rates
DS3000 - potentially the best but known to be noisy and, IMO, not fully tested on the car.
RS29 yellow - Well tried and tested but lower performing than the above. Less harsh on disks/wear rate.Its worth remembering that these pads hot are only just better than the RS15's cold!!!
One thing worth noting about both the RS15's and the DS3000's is that they will need more driver skill. Although I consider the modulation good, there is no doubt that it is easy to overbrake. When running standard pads, I cannot remember the abs kicking in at all yet if I am not paying attention, I can overbrake with the greys and get the abs cutting in. And that is on sprited road driving. At "Judgement Day", I didn't feel I was having that problem but then again, a stop watch certainly focuses the mind[
