Brake Pads Lights On
The Eagles
Does anyone here know the expected replacement costs of brake pads for a 992.1 GTS ('23 MYR). Do I go with an OPC (MOT due end of month) or independent such as Carr Motorsports? Warning lights first appeared last night, does this mean my pads are 75% worn etc? Many thanks.
IIRC the sensor light comes on then the pads are at 3mm.
As to where you get it done it’s up to you. An Indie will be much cheaper than an OPC as the labour cost will be a lot less.
Dan.
You need to get it done, mate. ??
My experience is once the warning light comes on, the braking system is way past its sell-by date!
You may need new rotors and fluid too.
Any good Indy can do it, but have in mind your Extended Warranty conditions.
Regards,
Clive
Lights came on with my 987.2 Boxster fronts a 5 years ago. The friction material thickness was alarmingly thin, but all 4 pads equal and worn nice and even (ie callipers are good).
Replace the lot (discs/pads/sensors) asap. Use a good brand, and imho road spec parts if a simple road car.
I did mine myself as it is very simple and quick, so an indie will be even quicker.
This way you get the full 'as-new' brake performance. New pads, old discs never a good idea.
You might even consider a fluid change if the time is due soon.
I used Brembo parts and once run in the braking was the same (!) as the old, but hard braking much improved. Run them in carefully.
The rears were the same 30K miles later.
Thank you gentlemen, sound advice. Unfortunately, I don't have the skills of 911hillclimber to do it myself, so the wallet will take a beating.
Booked into OPC for end of month to coincide with MOT, will have to drive like a sloth for 3 weeks in the meantime.
