brake fluid
- Thread starter dgw
sawood12
Just a few more questions:-
Is the ATE Type 200 an inferior product to ATE Blue as it is cheaper?
Is Castrol SRF a far superior product as I will be doing another track day or two before the end of the year so I might benefit - also what colour is it??
I take it all these products are Dot 4?
Cheers all.
It is conventional brake fluid colour (gold) but is outrageously expensive - that said one fill up with SRF is cheaper than having the bleed your brakes every couple of hours of track time (if the SRF works).
oilman
SRF is the dogs danglies but it is hellish expensive for extra performance.
Simon
Andy Duncan
I'll repost later in the year how the stuff has performed.
andy
ORIGINAL: 964RS
Use ATE Super Blue racing. DOT 4. It's excellent on the track. []
Completely agree, I tried dot 5.1 (generic & branded) after my brakes overheated at my first trackday, they still boiled just the same. Now use Racing Blue & haven't boiled it since, it's no longer the weakest link, and I've had no problems (that I wouldn;t otherwise have had) with the fluid in normal use either.
Then I started to get a hard 'dead' pedal from heatsoak (pads/disk too hot), added the early turbo brake ducts & they no longer overheat at all. Standard pads (so far) too [
ORIGINAL: AntB
So this stuff is good for normal road use also and normal regular change intervals?
It should last about a year, yes.
Peter Empson
ORIGINAL: eastendr
Castrol SRF ....
Same here, I boil the ATE fluid, but SRF is fine (I think it still boils/overflows slightly, but the pedal stays firm). I'm led to believe it is quite hygroscopic, so a yearly change is recommended (or more regularly if you race of course).
I used to use Castrol Response (a cheaper option) and that was good too, but not in the same league as SRF.
tr7v8
If I ever rebuild mine completely I'm going Silicone which is DOT 5 no hassle with moisture & rusty brake bits! I've run it in the past & had no problems & a guy who sprinted a Cat 7 used it again no issues.
Hilux
No need to buy anything expensive for road use - any dot 4 should be fine
True
5.1 is hygroscopic (absorbs water) so needs changing every year.
ATE blue or SRF if tracking the car
I found when hot it expands, at the Nurburgring with reasonably fresh pads and fluid (about 1000 miles) it expanded enough to overflow the cylinder. I use it on road and track and havent had any issues I change it every couple of years. I quite like EBC yellows as well as a road /track compromise but maybe I am less hard on the brakes than some. (hate Reds though)
Tony
Hilux
Dot 4 is hygroscopic, didn't know dot 5.1 was as well
Its not [8|][8|] its a typo, sorry - Note to self: must not rush type when replying
