Brake fluid capacity.
- Thread starter blade7
blade7
Well-known member
blade7
Well-known member
What method did you use to bleed the clutch? The clutch fluid in my car is at least 16 years old.I used less than a litre and had enough left to subsequently fill and bleed the clutch too.
Sealey Vs820 Brake And Clutch Bleeding System (was significantly cheaper when I purchased, quick browse reveals exact copies under different brands for less).
My clutch hard line could do with replacing as I slightly rounded one of the union nuts when removing. I was considering to change my setup to a flexible braided line all the way from the master to the slave. That way you can remove the slave cylinder and raise it above the master when bleeding, Plenty of DIY kits on ebay / amazon it would seem.
vitesse
Clutch slave cylinder is usually a pig to get bubble free but the female stamp does help considerably.
It does require patience (on both parties).
Brakes are a lot easier where I normally use vent tubes with 1way end valves fitted.
Unfortunately (or maybe sometimes fortunately) I don't have an "Irene" to press pedals for meI've tried my Sealey Easibleeder several times after making a heavy steel baseplate to sit it on using its magnet,Not as good as my longstanding alternative named Irene trained to stamp down the pedal at requested moments.
