Brake Conversions
- Thread starter Ryan944
Suffolk944
Moderator
Ps mine got VERY hot occasionally but never faded with that set up. Standard (quite worn) disks used to boil the fluid after 5mins of serious driving.
944 man
If the brakes are fading then Id suggest that youre braking for too long. Brake as hard as you can for as little time as possible and theyll get far less hot than if you brake less hard for longer.
Peter Empson
Braided hoses are a small improvement but would be low down my list. For fluid I have had great results with Castrol Response and SRF (the latter is best but expensive), for pads I use Porterfield R-4S (quite cheap if bought from the States and awesome - and I've tried an awful lot of different models/brands over the years).
That lot wont cost a fortune (£200?) and should solve the problem once and for all.
