Braided fuel lines
Dandrews
Hi everyone, replacing my fuel lines (40 years old) and went for braided hoses , for longevity and easy fit . Having problems with sourcing brackets/clips to attach to underneath car. Anyone bought these hoses(uk) , and have experience of fitting to underside . Thanks D.A.
The clips for the original hard lines were cheap enough and available from Porsche a couple of years ago when I purchased them. Check with Porsche, that is if your braided lines will fit into the OEM clips. If not you'll need to come up with a solution.
Stuart
Thanks for reply Stuart , I have a set of new Porsche clips , unfortunately they are much smaller than the braided hoses 1/2” (13mm) o/d . I have a set that I bought from the supplier of the hoses . Was hoping someone on here had fitted new hoses . Might have to refer back to original solid pipes !!!
We used cable-tie saddles on our rally cars.
Regards,
Clive
Thought about that one Clive . Problem is 2 fuel lines ( supply and return ) with only one self tapping screw on underside of car . Would require a double cable tie bracket which doesn’t seem to exist !
Not sure I quite understand the problem. Along with the solutions below there are also adhesive backed anchors available.
Regards,
Clive
Here's another solution for running the lines together in parallel.
Regards,
Clive
You've gone rather quiet Mr. Andrews but here's another possibility if the others don't suit.
Regards,
Clive
The factory clips also hold the brake lines. A previous owner had braided fuel lines installed on my car. From recollection, the factory clips were used but without the rubber blocks on the fuel line side. Hope this helps.
Thanks everyone for replies, thanks Clive for some good suggestions . All sorted now . Used a dremmel to expand ‘arches’ in original Porsche brackets .
Apologies for radio silence , just an old guy struggling with technology !!!
  • Like
Reactions: PSH
Was going to suggest somethingalong th lines of clives proposal but with a 3d printer or (3d printing service), sounds like you are sorted though!
Tony
