Boxster Valeting & Detailing
CLIFFWILKINS
Hi all Boxster members.
As a retired ex car detailer I thought it may be a good idea to share advice and any tips here.
Having just ceramic coated my wifes wheels ready for winter which can be seen on the Boxster fb page.
So feel free to share your tips I look forward to hearing from you.
Also happy to give free advice.
Regards Cliff
I would be interested to hear what members are using to keep the 'dreaded' external black plastic on there cars looking good.
I've tried quite a few products none of which seem to last long.
I use polytrol
Think I have used it a couple of times in 6 years - some say once a year.
Gtechniq g4 is also reckoned to be good. Not used that myself as yet (my trial size tin of polytrol is still very nearly full )
Hi Cliff
Any tips on the top of door cards peeling? Online videos seem to suggest using a 3M glue that's not available in the UK to re-glue them. Do you know if it's a tricky one to do as a DIY job or any organisations near/ in London that might do a good job?
Thanks!
Tim
Hi Tim.
Sorry to hear about your peeling door cards, you don't mention if vinyl or leather? If vinyl might be good opportunity to upgrade to leather.
Personally I would go to a professional outfit for a much better finish.
Take a look at a company in Enfield called B Trim
Regards Cliff
I was thinking pro would likely be best. They’re vinyl, and I’m actually looking at upgrading the whole car to a 718 ?
Thank you Cliff, they look great
On a separate note, any tips for paint shop too? I have a scratch on the front wing
Cheers!
Top Tip Might be time to carry out before winter sets in.
Might be time to clean and restore those soft tops.
I always Prefered reproofing with Fabsil Gold
Now winter is upon us wet weather, might be a good idea to put a windscreen repellant on the windscreen for a clearer vision something like Rain X but there are loads of products on the market.
Whats your go to on your Boxsters
I've just wiped my door seals with an anti-freeze solution (silicon?) to stop breaking the window motor wires on unlocking a frozen car. Worked well all last winter.
Did the boot and frunk seals too.
Tedious, but dropping the cap on the car roof every time after a drive in the winter. This stops the wipers getting iced to the windscreen, just to the cap which is easily moved to break a build-up of ice.
The roof on my 2009 987.2 has the start of small spotting. It lives close to mature trees…
I have just tried 3 applications of citrus cleaner, neat, and they are still there.
what could I use to clear the spore dots before sealing?
In the past I’ve tried Autoglyme and that level of products.
any suggestions please how to remove the spots?
Hi
Best method i have used
Hoover roof first
Use a rag top cleaner plenty on the market person choice Sonax gets good reviews.
You can mix in some white vinegar let it stand on roof agitate with a brush rinse off in bad cases a light power wash might be needed.
Let it dry then you can use some Milton's mould remover to kill the spores from coming back again rinse and dry
Hopefully clean and ready for reproofing again product used is person choice I use Fabsil Gold using a brush .
Cliff
