Boxster 987.1 2.7 battery generator fault
- Thread starter m300raj
I would check earth connections (battery and engine) and make sure the contacts on the alternator are clean and corrosion free.
Agree JeffYou’ve covered the main sources of your problem Raj. Maybe there’s a contact issue with the ignition switch?You could try squirting some electrical contact cleaner into the switch to see if that cures the problem.
Also worth checking the earth locations other wise a plug in to diagnostics maybe the answer.
all connections are good fault was there before replacement of complete new alternator and battery the fault did clear but came back after a few days luckly enough to get through new MOTWas the fault there before you changed battery and alternator? Is it a complete new alternator, or was the "regulator/rectifier" part re-used ?
Hi I have a diagnostic too and went to check the values the DME was seeing and it was not seeing any voltage even though the alternator is working fine with the new battery so not really sure where to look now any suggestions would be helpful.Looks like it's the DME that controls the light - and there is a value that can be read with the appropriate diagnostics (at least there is on a 987.2 - guessing the .1 will be the same) that will give the value the DME is seeing from the alternator - would suggest getting that read by someone/something that can pick up the value and see if the DME is seeing the correct value - if not that would point to a potential wiring fault between the alternator and the DME.
Then
Check the dme for signs of rodent damage to the wiring - it’s in the boot behind the bulkhead carpet left side as you look in the boot.
Check alternator end for any sign of damage or corrosion to the connector or wiring.
If not then you would need to pull the plug from the dme, find the pin and check continuity end to end.
If you are going to check the continuity then the end to end check is the most definitive.
You can possibly meter the signal at the alternator end to see what it sends.
