Boxster 987.1 2.7 battery generator fault
- Thread starter m300raj
I would check earth connections (battery and engine) and make sure the contacts on the alternator are clean and corrosion free.
Agree JeffYou’ve covered the main sources of your problem Raj. Maybe there’s a contact issue with the ignition switch?You could try squirting some electrical contact cleaner into the switch to see if that cures the problem.
Jeff
Also worth checking the earth locations other wise a plug in to diagnostics maybe the answer.
all connections are good fault was there before replacement of complete new alternator and battery the fault did clear but came back after a few days luckly enough to get through new MOTWas the fault there before you changed battery and alternator? Is it a complete new alternator, or was the "regulator/rectifier" part re-used ?
