Boxster 986 Radiator
- Thread starter Colind
https://www.pelicanparts.com/boxster/boxster_tech.htm
chrishak
Jack the car, remove the wheel and wheelarch liner. If you have air-con, you can remove two fixings then slide the condenser away from the radiator which might give enough access to get the radiator out but personally, I'd get the system degassed before starting, and remove the air-con condenser completely.
The hoses are difficult to get a firm grip on, so cut them rather than trying to save them, draining coolant at the same time (I didn't lose too much which is good as Porsche anti-freeze is outrageously expensive!). The rad is then easy to remove and replacement not too difficult except one or two hose clips are awkward buggers to tighten, but it can be done with dexterity and patience.
In addition to a new radiator, hoses and anti-freeze, be ready to replace various broken or corroded fixings, brackets and air-con O-rings (also ridiculously expensive) and use quality stainless hose clips - I found Jubilee type to be fine. Topping up the cooling system has a reputation for being difficult but I had no problem doing it.
I used Porsche coolant radiators and aftermarket air-con condensers.
All in all, not TOO difficult and satisfying when done - good luck.
Good luck!
