Boost enhancer?
- Thread starter JM1962
ORIGINAL: Eldavo
Fwiw I fitted a vacuum manifold made by the guy on Rennlist and it has a spare test port that can be used to pressurise the system.
Wont it leak out past the turbo intake?
I have a bung that fits in the pipe that normally attaches to the turbo outlet, think it was from arnworx.
Tony
ORIGINAL: 944Turbo
ORIGINAL: Eldavo
It's capped of under normal usage - just remove the cap and attach some silicon hose and a pressure source.
ORIGINAL: 924nutter
If you suspect an air leak then it is just as easy to connect up an old domestic vacuum cleaner in a similar manner in the drepression side of the tract, and listen for leaks, perhaps simply by comparing the tone of the motor with the suction hose covered to the tone you get when you connect it into the fanimold. Any lowering of the tone indicates an ingress of air. No not my preferred method at all. With all due respct and apologies.
I can't recommend this method at all!!!
After connecting the vacuum cleaner to the fanimold there was a very noticeable change in tone akin to a loud shriek. I then got hit in the side of the head so hard that I lost consciousness.
The tone has definitely been lowered
ORIGINAL: Eldavo
ORIGINAL: 944Turbo
ORIGINAL: Eldavo
I meant when you try to pressure test the intake, pumping air in to the spare port it will go out through the turbo and then the airfilter.
Tony
