smallspeed
on the way home last night i pulled up at a junction and the dashboard started beeping (from behind the clocks) and the ABS and "!" light's came on.. As i sat there staring at my dash the battery light started flickering too but really dimly.. Occasionally if I've been doing a few short trips I've had the ABS light come on before when I first start the car (although never heard the beeping) so I gave the throttle a little blip and the warning lights went out and the dash stopped beeping.. Next junction same story, and again, and again.. I assumed maybe the battery had died and needed replacing.
I pulled up outside my house, no beeping, parked, turned off. Then I thought I'd re-start the car incase the battery was dead, as I was pretty sure if it was flat enough to trigger the ABS light it would be totally flat, plus I had only driven about 1 mile in stop start traffic since the beeping first appeared.. Anyway, cranked, fired, everything fine, no sign of any warning lights..
Went out this morning, car started first time drove to work. Had one stop at a roundabout, and the beep and warning lights came back.. Blipped the throttle, problem went away, hopefully never to return.. It seems it happens when I apply the brakes rather than if the car is just sitting ticking over, so Im wondering if its brake or ABS related
Anyway, I don't think its the battery (correct me if Im wrong) as the car starts fine, and seems to be holding charge, but Im wondering if there is a second battery somewhere for the ABS system or if a short, a dodgy relay or a dying fuse in the ABS circuit might cause something like this?.. Doesn't happen all the time, just occasionally
If anyone can shed any light on this beeping, and the ABS/battery warning light I would be really grateful; I get the feeling it might be expensive, but im hoping not!
Thanks in advance
Ben
PS.. I had just driven about 450miles in two sections so the battery should have been fully charged?!
PPS.. I have been really slack; I replaced the front brake pads a month ago, and couldn't get two sets of pad wear sensors. I have a second set now, but only have one side fitted to the car at the moment.. Could this cause the problem?.. Its not caused any issues for the last 3 or 4 weeks, so Im thinking not, but thought it worth mentioning incase
PPPS.. Assuming the ABS wheel speed sensors feed the OBC digital speedo, they are all working correctly, although my rev counter did "pass out" for an hour on saturday. Turned off and restarted the car and it came straight back to life. OBC was working fine, just the rev counter needle went to sleep!
Thanks in advance
Ben
