OK, promised some time ago to put pictures here how to modify original Sachs struts to accept Bilstein Sport inserts.
Started yesterday to put into parts few sets of original Sachs. Struts are now in parts and still having an overnight citric acid path. I'll go today to sand blaster's place to have struts blasted. After that they will be modified to have some threads, which allows Bilsteins to be screwd in. Struts will be powder coated as well. A former 968 set will be done firts; it will go under my friends S2 cab, which i am just converting to Turbo cab. Engine came from Steve/Alasdair
Starting point. A former 968 Sachs strut. Got this set up from a friend of mine, he changed to Koni yellows we refurbed for his 968
Konis we made for 968
OK, here's what i have done so far. First remved the top cap. I just cutted it off using an angle grinder
Next just cutted the pressed section off the strut off. It's not that accurate where to cut at this point. Just have something under the strut where to collect oil....
Now carefully pull the piston out. Remember there will be abouit 2-3DL oil inside the strut.
Few sets to go
I removed Tectyl undercoating from the struts. It is nice job to do for a blaster man... Undercoatings are pita to blast away [
Now i just need to take struts off the citric acid bath. Put them to bath just to help blaster mans work.
Will put more pictures when project has gone some steps furter.
Few sets to go
