Well it's done and looking good.
I've gone with Eibach springs, with a main spring and tender. The tender means that the car has soft suspension initially then they compress and the main spring takes over under harder use.
I did speak to Chris for some advice on spring lengths and rates. Gone for 228lb front and 457lb rear. Chris was fantastic, he spent quite a lot of time on the phone with me and sent me some spring perches which he said to pay for if I end up using them.
Also put on a set of drilled discs I had sitting around and a set new of EBC yellows. Found a split CV boot whilst I was under there so changed that too.
Here it is now, what do you think ?
