Battery Voltage
stephen.robins
Can anyone advise on what the battery voltage should be when the car is cold and at this time of the year? My car is garaged but if left for a few days the voltage only reads 11.9V. I would expect it to be over 12V. It always starts and the stop/start appears to work fine which I think is a sign of a healthy battery.
The car is only 3 years old and had a new battery installed before I purchased the car. I'm just a little paranoid that I may have a drain?
A drain? There will always be a low current draw to keep your car “alive” to respond to key fob unlocking, alarm and monitoring etc. I think the owner’s manual advises to not leave uncharged (by driving or charger) for more than a month.
Bill
Hi Stephen,
11.9V with the engine off sounds a bit low. You should be looking at something like 12.6V - 12.8V for a fully-charged battery, although it’ll still be serviceable at around 12.4V - 12.5V.
You don’t mention how you’re measuring the voltage, but you would best measuring it with a multimeter rather than relying upon the onboard voltmeter.
If you can I’d always advise you to use a battery conditioner if the car’s not in daily use, especially at this time of the year with temperatures falling.
Jeff
Hi Stephen,
Jeff
Jeff,
Thanks for your reply. I'm taking the voltage reading from the dashboard. By comparison, my 981S never shows less than 12V before starting.
I have connected my battery conditioner this morning and it has been on for a few hours and is still not showing fully charged so it looks like the voltage was low.
Steve
Have you checked the voltage with the engine running? If it is not above 13V (see Dan's chart), the alternator may not be generating a high enough voltage to keep the battery at the optimum level, but could still be fine for stop/start.
Thank you all for your comments.
Having been on the conditioner all day, it showed 12.2V before starting this morning. Running it is showing over 13V and all appears to be ok.
Steve
I had concerns about the battery in my 2020 car when I bought it in 2023. The voltage was often below 12v (as displayed on the dashboard) and I tended to use a CTEK charger when the car was not used for a few days.
On a trip to the factory with the club I found the battery showing 11.8v the morning following the long drive to near Stuttgart. I was worried about this and booked the car into my OPC immediately on my return.
Whilst the battery was not in the best condition no fault was found but a new battery was kindly fitted at the OPC's expensive.
The voltage each day varies but is often 11.9v. I ocassionally use the CTEK but the voltage never goes above 12.2v. Several technicians including the after sales manager have re-assured me that this is normal for a 992 as the charging system is unusually complex.
Keith
My 992.1 GTS tends to show 13.4v while I am driving, not all the time, but it's pretty consistent in showing 13.4v most of the time. I have the lithium battery though which I understand may be slightly different
