Bar Reading on Turbo
- Thread starter wingco
sawood12
It's best to test your boost level on a slight gradient in 3rd and 4th gear and you should hit max boost around 3200 to 3500 rpm. If you're not achiving full boost is is most likely to be your wastegate housing being cracked thereby preventing the exhaust pressure to build upto where it should be due to exhaust gasses leaking through the cracked housing. Mine was like this and as soon as I replaced the wastegate for a dual port wastegate I noticed a huge improvement in boost and I got 240bhp at Weltmiester when max boost set to std levels with stock chips so even a good OEM single port wastegate is costing you 20bhp (mine is a 220bhp car).
Check your wastegate housing - you can see it from under the car. The housing is cast and has cooling fins cast into it. The cracks happen in the valley of the cooling fins.
I would check over the engine bay to see if any obvious pipes have come loose, then check the big rubber intercooler pipes for splits. Then read the Wastegate troubleshooting section in the Garage Shop Manual at www.clarks-garage.com
After that take it to a good independant and look forward to lots more boost [
