bumperblue
Over the last two nights have been fitting two ball joint kits supplied by Design 911. Thought I would give some thoughts for anybody else thinking of doing it.
The kit is adequate, the plastic bushing seems well made and substantial (we will have to see about wear over time ) and the ball joint itself is well machined and everything fits as expected. Couple of issues, the rubber boots supplied are quite thin and flimsy compared to my existing Porsche ones, noticeably so and I split one slipping it over the flange. So I cleaned the old ones up which were still in fine condition and reused. The biggest problem I found was the sprung ring/washer which holds the dust cap in place and prevents the spring popping out. The swing arm is extremely light alloy and surprisingly soft, where it has been machined in the socket to take the sprung ring was it obviously made exactly for the Porsche ring and I found the design 911 ring would not expand and hold the dust cap back under the force of the spring it almost seemed to burr the metal. I solved this by buying a couple of proper spring clips (the type with eyes on the end) and these fitted really well and were very solid. Have now filled the socket with epoxy and will fit back on car on Saturday.
Overall a 7/10 for the kit. The american ones look to be quite a bit better and more complete kits (particularly the metal bushed ones) but at a much greater cost once shipping and import tax is added. In my case its a daily driver and it failed its MOT so time was a big issue.
Its an OK job for you average DIY'er.
Have fun
Ian
Have fun
Ian
