Awkwardness of a simple task challenge.....
- Thread starter scam75
edh
robwright said:Ha ha yes it is equally as bone on a Turbo. How about changing the ICV without removing the entire intake manifold......oh wait you can’t.
The design is different on the S2 - which uses a single screw to fix the 2 hoses, whereas the turbo (from memory) has two separate screw on hose fittings.
Hard to explain but - one of the two s2 hoses has a metal plate on it, which slides onto the other hose & presses against the flange on the hose end. (It only fits in one orientation as the flange has a flat side that has to marry up) The single screw goes through the middle of the plate into the cooler & secures both hoses
jonnyporsche
