cayenneaero
My Cayenne S seems to have a immobiliser problem. It started off with the keyless system not working, I took it into my local Poesche dealer and they said the problem was that the keys required new batteries and repair.
I had the vehicle back and within a day or so tge problem came back. Thr problems are because of tge fault;
*key does not work on the KESY system
*when entering the car the alarm sounds, however you can start tge car and the alarm will still sound!
*the car is equiped with a tracker and when this happens, it cut the power to the tracker & tracker uk are forever on the phone as a alert consequence
*when it totally cuts out all power, it send all types of warning lights etc on dash board and I mean random messages
*I can be sat in the car and turn the engine off but leave tge ignition to the first turn and it will decided to lock all controls including locking the key in the ignition barrel for up to 5 monikers, there is nothing I can do about it until it clear it self!
Has anyone experienced this problem before or anyone know what this could be? Is it an expensive repair?
Thanks for you time
Thanks for you time
