Anyone running KWv3's ? How's the build quality, warranty and service?
- Thread starter bebbetufs
Never had a problem so don't know about customer support.
Gerry
edh
Tech support guys are very helpful, haven't had to use them for rebuilds yet but I believe they have to go back to Germany so not ideal.
adjusting rear rebound is a pain as you have to remove the shocks - apart from that, everything works well. I adjusted front ride height after the dampers had been on the car for a number of years - no corrosion, no stuck platforms - excellent [
edh
See my thread - I have increased the spring rates a bit - v3 is a road car setup really, which works on tracks but maybe could be improved on. For a track focused car I'd be tempted to look at a custom Gaz setup from EMC, but I wouldn't expect them to last as well. Gaz are much cheaper though so only to be expected.
I had a quick read trough your tread, seems like a similar build to what I'm thinking about. What spring rates are you running and did you have to have them revalved? Also, will running different springs void the warranty?
I searched for the GAZ coilovers but got no hits. Are they not very popular?
edh
the springs were from kw - and no I didn't get them revalved (this is a budget build..)
Gaz Gold - with custom spring rates from EMC http://www.emcmotorsport.co.uk/ They know a lot about 944 race car prep.
Standard Gaz Gold - http://www.gazshocks.com/ - probably a bit more guesswork required on springs - although you can specify whatever you want.
ChasR
From what I can tell, for an out and out track car, the EMC Gaz setup (with remote reserviors) really does take some beating on the track, with it being race proven by more than one person (in addition to a couple of chaps driving with both KWs and then the Gaz setup
ChasR
I should have said road legal, not road worthy. I meant a certificate to show the authorities that the shocks have been tested and approved for use on the 944 Turbo. Like the TÜV certificate the KWs have.
I'm intrigued by the GAZ option and want to read more about it, unfortunately I keep getting no hits when I search the forum. Surely they must be mentioned in other threads? I would like to know more about spring rates and valving. Are they meant to be run without torsion bars? How do the spherical bearings hold up to rain and dirt from the road?
Ex Skyline
