Anyone attempted 997 seats in a 944?
- Thread starter h4x0r7000
924Srr27l
h4x0r7000 said:Wondering if its possible? Has anyone attempted any other Porsche seat inside a 944
Yeah anything's possible from a Skilled fabricator to design and make bespoke brackets as long as they will physically fit.
I'm guessing you've seen some for sale and are wondering if they can be made to fit ?
If they are like these, they look fairly slim but you'd need to measure...
I'd be 99% sure the runners won't line up with the 944 captive nuts in the floor........
R
John Sims
PCGB Admin
That said, if the new seat runner mounts are in board of the 944 you could perhaps use a reasonably robust steel angle to bridge to rear floor mountings to give you new mounting points.
924Srr27l
John Sims said:In the good old days it wouldn't have been a problem to fit spacers, bridging brackets etc. Now, with the seat belts fixed to the seat frames, a contorted connection between the seat brackets and car structure could be down right dangerous and might fail an MOT. And you cant just drill new holes in the floor as they may not tie up with a structural rib.
The 944 is from the good old days, and the seatbelt mounted points are not on the seats but the B pillar and the side of the tunnel
So you can fit any seat you want with any brackets / frame and use the standard seatbelt mounting points
No need to drill holes in the floor, the 4 Captive bolt holes are fine for a frame to be made to suit the new seats mounting points.
R
Cheers for the replies. I used to have a Cayman S and loved the seats compared to my 944. I'm looking to improve the 944 interior with modern seats, all black interior, remove the rear seats and add the club sport seat delete kit. I would also like the 19" sport design alloys
924Srr27l
h4x0r7000 said:Hi All,
Cheers for the replies. I used to have a Cayman S and loved the seats compared to my 944. I'm looking to improve the 944 interior with modern seats, all black interior, remove the rear seats and add the club sport seat delete kit. I would also like the 19" sport design alloys![]()
Ok, the 997 seats should go in then with some Fabrication!
I'm with you on the black Interior and Rear seats Delete,
But NOT 19" Wheels unless it's for "show use only" they are not suitable
for many reasons !
17" Max unless you want slower acceleration? and to have a 944 with appalling & poor: ride, Economy,handling and driving traits etc....
R
GlennS
924Srr27l said:The 944 is from the good old days, and the seatbelt mounted points are not on the seats but the B pillar and the side of the tunnel
This is not true of the later 944s which have the seat belt receptacle attached to the seat frame and use 6 captive bolts on the floor.
924Srr27l
GlennS said:924Srr27l said:The 944 is from the good old days, and the seatbelt mounted points are not on the seats but the B pillar and the side of the tunnel
Yeah true the later type's used that bracket which bolted to the seat Frame, the prospective 997 seats also have that arrangement which could be used in the same way or I wonder if the captive nut in the body is still there on later types?
The old ones are the best lol!
R
924Srr27l
944 man said:986/96 seats will fit 924-derived runners. Late cars will require late runners and this will be harder to achieve than people realise, and usually involves importing lower spec parts from LHD markets.
"Will Fit" does that mean direct? or with the aid of a grinder, drill and hours of work modifying etc..,
The seat rails on 986 / 96 go across left to right not front to back like the 44 has and the prospective OP's question is for 997[/b] seats, do they fit as well? or as above do they also have to be modified.....
R
The original seat is on the drivers side:
The mounting rails line up but you need to bend the tabs up on the front:
and cut off the pin to the rear:
There is a gas- shock that controls the height. The other write-up says to cut this off. I could live with the slightly higher position so I left it on.
I had to rewire the connectors for the power seats, it's only a couple of wires:
Really not that bad of a job. I like the way the new seats feel and the support. Look good too! I'm 6ft/200lbs and have plenty of legroom, but the seat is a little higher.
Hope this helps if you are wondering about seat upgrades. I'm really happy with the results.
924Srr27l
h4x0r7000 said:what I've found:
Legroom doesn't look too bad, although that steering wheel is smaller than OE.
So a bit of bending, wiring and cutting about and they're in!
Just the steering wheel now needs moving over to the right [
R
