Lots of dash left - I think this is a little sparse however -
But even this had the heater still in!
ORIGINAL: PSH
Hi Lawrence
Regarding bleeding, first make sure the car is on level ground, on top of the cylinder head at the front right hand side as you look at it from the front, you'll see a short reducer water hose fitted to an alloy elbow. On this elbow you'll find the small bleed screw, bleed as normal ie, unscrew with engine running and let air escape until free and then re-tighten screw. The 944 has a great cooling system but it's not the easiest to get the air out.
Good luck
Pete
ORIGINAL: PSH
hmmm
Do you know if it has any history of a head gasket change? do you know if your loosing any water before it overflows from the header to suggest that the gasket may be on it's way out? I can't remember but to save me re-reading the thread has the fan switch been checked or replaced?
Pete
ORIGINAL: LawrenceR
ORIGINAL: PSH
hmmm
Pete
It has had a head gasket change, from memory, in 2010. I do not know if it is losing water before it overflows. Fan switch or thermostat has not been replaced. The problems have only come about since we removed the pipework for the heater matrix though, removing the solid pipe that runs along the rocker cover and replacing this with a rubber pipe.
From what I have read on an American forum, the temp gauge getting to half way, is not overheating, its just whenever I go for a drive, water overflows when I stop.
ORIGINAL: A9XXC
Maybe the coolant cap I had the same symptoms with mine on the Dyno Day in Liverpool if you remember Pete? Guy replaced the cap and that was the end of the problem.
Also had similar on the 2.7.
