Hi all,
Came across these little babies and wondered about fitting them in the old girl at some point if it is do-able ...
Anyone tried this or maybee see any problems - main issue would be placement of the blower box - trunk ? possibly , then pass tubes through (hate idea of cutting, butchering metalwork though)
But this would seem to eliminate the need to use the standard heater system and I could opt for cheaper exhaust and not 'gas' myself in the process.
I don't know really playing with this in my mind - so would love comments jokes and feedback.
looking at around $190 but I hope there are cheaper / other systems out there - say from marine suppliers - I found this one on:
JCWhitney USA
Small enough to mount almost anywhere yet produce an amazing amount of heat?up to 28,000 BTU/hour!
Heavy-duty 3-speed 12-volt blower
Huge airflow?up to 263 CFM!
On/Off-road Heater Kit with Ducts 9.4"W x 6.4"H x 9.35"D
Want you and your passengers to stay warm in your on- or off-road vehicle? Choose one of these heaters! Both use warm engine coolant to help you keep comfortable when the weather turns cold or when driving with the top down. Heavy-duty steel housing with tough black powder-coat finish. 3-speed operation: 172 CFM (3.9-amp draw); 228CFM (5-amp drow); 263 CFM (7.7-amp draw). Weigh only 7.2 lbs. Kits include heater, mounting brackets, wiring harness, switch and bracket, stainless steel mounting hardware and instructions. Heater hose not included. Manufacturer's 2-year warranty.
JCWhitney USA
